- Jul 12, 2006
- 111,807
- 31,255
- 146
Hey all,
I'm currently redoing my kitchen in stages--have some counter guys working on pricing and will install new quartz countertops for me, but the rest I plan to do myself (tiles, "new" island, virgin hardwood that I need to reclaim and finish from beneath the garbage vinyl tiles that some jackass glued on), and have the new faucet and sink on the way.
I'm trying to decide on instant hot water dispensers, as it's something I've always wanted. I'm not finding a lot of good reviews (mostly advertising garbage that disguises itself as product reviews, you know what I mean), so I'm wondering if any of you have longterm experience, either good or bad, and have tips or specific warnings.
I'm currently looking at this one from Insinkerator....I guess most of them are insinkerator, and so it's hard to compare among diverse options.
I've learned that tanks with rubber bladders tend to have higher failure rates, to probably stick to stainless steel tanks and that, no matter what, these things have a pretty high failure rate within a year, anyway, so it's hard to make a solid choice, based on ~honest reviews. Though I'm not sure if that's usually just user error.
My main use would be for instant clean/sterlization--rinse dish immediately after use = clean. I have a dishwasher, but I don't like using it. I'm not a high demand dishes person, so I only run it once ~ 2 weeks. And I don't do a lot of sink washing, it just slowly accumulates because I do a lot of reuse between washes. Also, I just don't trust my dishwasher.
So, that, and quick single cups of coffee, noodles, things like that.
So...any "run away in terror now!" stories or "buy it now! the ladies will toss their panties at you when you install one!" type of advice?
...I will also need to replace both the hot water and cold water undersink valves (hot is actually not cutting off all the flow when it is closed), and was thinking 2 dual-outlet valves, and adding a T-junction to the cold water outlet valve shared between dishwasher and this (potential) hot water dispenser. ....my water pipes are copper and I was thinking of going with compression fittings for new valves--that is standard, right? Much of the water pipes are exposed in the basement, and I've replaced a few myself, learning how to solder and all that, but outlet valves are typically attached with compression fittings? I sometimes worry about the solders on my pipes because they are...I don't know how old, and I have experienced waterhammer, some weird flow problems from time to time (I think I discovered the errors that I made the last time hammer happened--just not properly emptying some of the toilets/sinks when I was working on pipes and the water was off).
....any further advice on hardware for this? I want to make sure I get the proper valve for the hot water outlet, making sure it's rated for long-term hot water flow...assuming there is a relevant difference. I always thought there was...
