- Sep 25, 2001
- 29,391
- 2,738
- 126
I have a deep soaking tub that i use off and on in the cold winter.
I usually up the temp of my water heater to near max, and wait a couple of hours for the water to heat up. Then run the water for the bath tub.
While the water is running, i also turn down the temp on the water heater back to normal temp so i dont get burned when i take a shower next day.
Edit: And waste energy since i dont need a tank of super hot water to take a quick shower
Instead of waiting 2hrs, are there any small 'instant hot' water heaters that could work?
