Installing Win XP using a SATA DVD drive, possible?
jlbenedict
Banned
Jul 10, 2005
3,724
If the chipset controller and its SATA connections are "native" and the drive is bootable, then it should be no problem.
GreenGhost
1,272
I thought I was going to get stuck yesterday with this issue, but I just put the XP disk and everything worked like a charm. I was installing on a Gigabyte 965P DS3, LiteOn SATA.
gwag
608
my guess is the motherboard has more to do with it than anything. ( like how you can almost boot into windows 95 from a 10 year old 2G hard disk via usb, but if you plug that usb hard disk into a windows 95 machine it will just laugh at you.
Pirotech
352
it's possible if windows can detect sata controller without installing sata drivers in addition.
