Installing Thermal Sensor with golden orb! help!
badxcow
72
ok i dont know how to install the thermal sensor for my be6. the manual says "when you tape the thermal cable onto the CPU's heat sink, tape it near the CPU chipset" since im guessing this is for the standard intel hsf, im confused. how do i install it with my golden orb. do i slap it directly on the core? does this mean i slap it on the core then slap the gorb on top of it? somebody help! i have celly2 566@707 default cc0 1.7v and am afrid to go to 850 becuase i cant chek my heat! help! how do i install it!
btw
i have the cc0 so wats the highest voltage i should go up to wen ocing? i have golden orb and just bought two case fans
badxcow
72
hey i installed it just like in the picture..i found some thermal tape..but..for some reason in my bios it says temp N/A and in mobo monitor it shows the temp at -48c! constant and non changing. this is wronggggggg rite? wats up? could the thermo sensor be messed up? where can i get a new one? help! thanx guys
