marketsons1985
I'm installing a couple of interior neons in my car, and this is what i've decided to do.
Instead of wiring them directly to my existing wiring, I'm creating a box, that will plug into the cigarrette lighter. The neons came with just wires, no plugs on the end. The box will have a switch, and I need to create some sort of parallel circuit so that both of the neons get the same amount of power.
I was thinking of running the wires through the switch, then branching off of a wire running out of the switch, as opposed to attempting the parallel circuit through the switch. My two options are in the following link.
Sorry for the poor paint job.....made it early this morning.
Circuit
Let me know what you think, or if you have a better idea!
Circuit
