I'm building a computer for the first time and I'm about to install the motherboard to the motherboard tray. (FYI Asus A7V133 to Addtronics A6896A case) Included with the case were two types of metalltic motherboard risers and these cardboard (?plastic; definitely not metal) washers, and a ton of screws. I think I remember reading somewhere that the motherboard cannot come in direct contact with the motherboard tray. Anyway, are these washers used to prevent this from happening? Should they go between the screw and the motherboard, or the motherboard and the riser, or between both? Or, are they not used for this at all, and I'm making this all up in my head?
Sorry for the dumb question, but there weren't many instructions with the case.
Thanks.
Thanks.
