Installing monitor drivers problem
high
Banned
Sep 14, 2003
1,431
I'm trying to manually install my monitor drivers because XP just picks it up as a Plug and Play monitor. Now when I try to update the standard PnP driver, it won't let me use my monitor one that I downloaded from NEC's site, and when I remove it and don't scan for changes, goto manually add hardware, I cannot add a monitor. Anyone have any hints for getting these installed?
high
Banned
Sep 14, 2003
1,431
Wondering if the ghosting I am getting in games has something to do with drivers...?
us3rnotfound
5,334
Dude, don't worry about if XP detects the monitor as Plug and Play. It's the same damn thing ;).
TourGuide
1,680
Try booting into safe mode and uninstalling the drivers there. Then reboot and see if you can install the drivers then.
