I've wanted to setup Eterm in my home directory at school. I'm unsure of what version FC it is running, but probably not v6 or 7 (maybe v4 or 5, though no idea how to find out such a SIMPLE thing in PITA linux).
So the dependencies for Eterm 0.9.4 are libast and possibly libim2. Due to dependency horrors I figured I'd install both. So I found the .tar.gz packages for each, ran
gunzip file_name.tar.gz | tar -xf -
which extracted them to a directory. I went to that directory and typed
./configure
make
libast seems to configure and compile without error. imlib2 has an error of 'label at end of statement'. But I don't think I really need imlib2 because when I try to ./configure Eterm, it says only libast is not present and required (and tried to auto-get it but failed with "no route to host"). So libast seems to compile fine, but it either isn't there or isn't registered so that Eterm knows of it. When I go to the libast directory where the tarball was extracted to and type
libast-config -ldflags
It prints: -L/user/lib -L/usr/X11R6/lib
No idea what that means, but I can't find it present in the /usr directory and /user is no such directory.
Any idea what to do?
./configure
make
