Installing Internal wireless NIC. I need an antenna.
TriggerHappy101
1,006
I ordered (and installed) an internal wireless NIC for my HP Pavilion ze4600. Hower - I made the mistake that I needed an antenna installed also (I thought one was already installed.)
The wNIC:
MSI MP54G5 (MS-6833B) IEEE 802.11b/g
http://www.newegg.com/Product/Product.asp?Item=N82E16833158015
I need an Antenna now for this type 3 wNIC. Do I need a specificly made one for my laptop? Or do they make genieric antennas? Thanks!
TriggerHappy101
1,006
Yes this is for a notebook. It is able to see my AP from about 7 feet away with 35% signal strength. It needs to be connected to an internal antenna that lives inside the laptop case.
corkyg
Elite Member | Peripherals
27,370
240
In that particular Pavilion, you will not find a built in antenna. It would have been a lot simpler to get a good PCMCIA NIC and just stick it in the slot. The antenna is built in to the card.
NIC
corkyg
27,370
240
Originally posted by: TriggerHappy101 I dont like the thing hanging off the end.
Wierd! I use my EVDO connection card all the time, and when I pack up, I remove it from the slot and slip it into its padded bag.
Hanging off the end? A 3/4 inch protrusion ain't no biggie. I don't think you'll find any suitable antenna in a store - there's no real market for them.
