So I'm setting up a small woodstove in my addition to reduce my excuses for not finishing it ... you know ... like "it's to damn cold to work out there today"
I'm using double wall duravent pipe to connect the stove to my triple wall duravent chimney. But nowhere in the instructions or pictures does it show anything installing a flue damper ... you know, that handle on the chimney pipe you use to control the draft.
Do I just drill it like a normal single wall pipe, or is there something special I need to do. Of course, the dealer I bought it from is closed today :roll:
