shurleydude
I got myself an Athlon XP 1900+, the Asus 220D nForce MATX board, and a Volcano 7 HSF, I also bought a shim to put on top of the CPU...
This will be the first time I've ever installed a CPU before.
I've read through the installation techniques from thermaltakes website along with AMD's website, but still have a few questions...
Since this is my first time, is it very easy to crack the core while putting the HSF on?
With the Shim on, will it be hard to crack the core?
Do I just take the peeling off the bottom of the HSF and pop it on the CPU and then secure the little clip on the socket?
What do they mean by "not applying direct pressure on the HSF?" How do i put it on the CPU without doing this???
Since I won't be overclocking, should I use my Artic Silver instead of the standard stuff that's underneath the thing I peel off or should I just use the standard stuff?
And any other tips if you have any please 🙂 Thanks so much!
