Aikouka
I'm looking to finally install my water softener. I've had it lying around for a while, and my major hold-up has been how to properly drain the unit. I do have an existing water softener in my (rather tall) crawlspace that has been disabled for quite some time; it was bypassed when I got the house, which (arguably) was a bit of a red flag. Anyway, the problem is that it was likely never installed properly as it doesn't have any sort of up-to-code drain solution. It looks like their previous implementation drained to a clean out plug as the drain tube is dangling over top of it.
My current plan -- and what I'm looking to make sure is acceptable -- is that I'd like to move the water softener to be near an existing drain pipe that I can modify to serve as two separate drains. The current pipe comes up vertically from the main sewage line into a sanitary tee. The vertical of the sanitary tee connects to a vent. The horizontal of the sanitary tee connects to a p-trap, which then goes up and into a washing machine box to serve as a washing machine drain. My plan is to replace the existing sanitary tee with a double sanitary tee. The two existing sides would effectively remain the same, and the added horizontal opening would somewhat mirror the washing machine drain except it would terminate at a dual air gap (has two 3/8" connectors).
So, I guess the questions are...
- Is a double sanitary tee the correct solution? I did a bit of research and it looks like this is the correct choice over something like a double wye. It appears that the difference is in the orientation of the pipes.
- In regard to codes involving proper p-trap installation, it looks like the only rule in play is that the vertical section shouldn't be more than 24"? Given that the one drain is gravity fed, I need a relatively short vertical piece anyway.
