HomeBrewerDude
I started to install a ceiling fan. There is a light fixture there already. The house is approx. 50 yrs old.
Problem number 1: Replacing the box for the existing fixture with a box and bracket designed for a ceiling fan.
This involved crawling up into the attic to access the pre-existing box and brace. The brace required a hacksaw, and the location is such that there is only 2 feet of space between the joyces and roof. Futhermore, its 110 degress up there.
Problem number 2: Light fixture and wall outlets are all wired together for this room (and two others!). Wiring is old, 2 wire in a flexible metal sheath.
I haven't quite decided how to address this. I will probably just leave the current wiring as is, but it is tempting to start the re-wiring project that has been floating around in my head for a while. This will involve running new wire to outlets, and putting ceiling fixtures on a different circuit.
UPDATE: I finished this project tonight. It actually works the way I wanted it too. The wall switch controls the light, and the fan can run independently of the wall switch and is controlled by the pull chain.
Cheers and Beer for ME!
