Installing 8Ohm speaker and tweeter to a 4ohm impedance amp
Jade_inc
13Gigatons
7,461
500
I'm doubtfully the car amp would work that well on the 8 ohm woofer. It's designed for 4 or 2 ohms loads. Car amps produce less output voltage but increased current which is what is available in cars.
You could wire two 8 ohm woofers in parallel and get a 4 ohm load though.
crashtech
10,695
2,293
The efficiency of the linked woofers is high, and the Vas is suitably small, but Xmax is rather short. Two in parallel will probably work if a suitable enclosure can be designed.
