Originally posted by: MikeyIs4Dcats
usually it will still power up even if not grounded. Make sure ou have good connections on your crimps. it's easy to get a wire loosen up while installing.
How is it gonna power up without being grounded?
Originally posted by: wasssup
used this guide to install it, everything works but the damn radio doesn't turn on.
i'm guessing it's not grounded properly...do i actually have to ground the radio to the chasis? (i just crimped all the "ground" wires together and that was that).
This is a '99 Civic EX btw.
Originally posted by: Aimster
There is an antenna adapater for most in-dash car systems.
You have to purchase it.
It makes the antenna go up.
Yeah but my battery is REALLY bad. After I put the dash back together (a chore with my car), with the car in ACC mode I:
(1) tried the wipers - they didn't work.
(2) put my lights on - when I did this the radio stopped working.
I then started my car and the problem disappeared. Looks like I better buy a new battery this week.
