Well you can use some Zip Tie Mounting Bases,these are flat pieces of plastic with adhesive on one side and a loop for the zip tie on the other.That way you can neatly route those power cables.There is also an IDE version used to neatly route those flat IDE cables.
PS
I dont think i will ever put together a pc (for me or immediate family member) without 'em.
