$@#$ing eye floaters...
j&j
246
good to hear insurance covers if it I ever decided to take that path I'd at least be only responsible for my maximum annual deductible. pretty much just need to wait on the opinion of my opthomologist now
Apr 17, 2003
37,622
just a heads up...opthos are very hesitant to go this route (I bet your optho won't even mention it as a treatment option unless/until you bring it up).
njdevilsfan87
2,331
251
I almost got into a car accident one day because I kept following this one around in my vision...
Jeff7
41,596
19
And hell, I know that I'd be hesitant to go this route.
Sure thing, just suck out some of my eye goo and see if that does anything.
Here, start with this eye first.o_O
Apr 17, 2003
37,622
The complications are very low. 2-3% chance of retinal detachment (which can be repaired) and 1 in 3000-5000 chance of infection (lower than lasik). For some people, it's bothersome enough to warrant the risk.
natto fire
7,117
10
I forgot that I couldn't really see them unless I was focusing a certain way until this thread, damn I have a lot that appeared for a bit and then went away again. Also a lot easier to see if you close your eyes and take deep breaths.
ShinmenTakezo
19
I am an ophthalmology resident, so I have some knowledge in this area. I am still in training and am not a retina specialist so take what I say with a grain of salt.
The "floaters" you described are a posterior vitreous detachment(PVD), caused by breakdown and liquefying of the vitreous, a gel-like substance which fills the posterior segment of the eye. These are extremely common and while annoying, don't require any treatment. While the floaters may seem like a major problem if you haven't had to deal with them before, I would recommend giving it some time. Generally the floaters will settle at the bottom of the eye, and eventually your brain will learn to ignore and "see around" the floaters to some degree, making them less noticeable. Someone earlier in the thread mentioned laser and surgery as options for getting rid of the floaters, but I would recommend extreme caution before proceeding with either of the two options.
There is a doctor in Florida who advocates treating PVD with the Nd:YAG laser. Zapping the PVD with a laser won't actually get rid of a PVD, it will just break it up. Now instead of a large floater, you'll have multiple smaller floaters which may or may not be an improvement. Safety-wise, the incidence of retinal detachment associated with the YAG is close to 0, however, the laser is typically used to treat parts of the eye more anterior and usually requiring few shots. Trying to vaporize a floater would require the laser to be directed more posterior which would require more energy and more shots to be effective. The YAG works by creating a small shockwave inside the eye which is not something I would want close to the retina. I'm not aware of any studies looking at incidence of retinal detachment following YAG laser treatment of PVD, but I would imagine from a physiologic standpoint that it would be higher. My opinion is that laser treatment for floaters is of questionable efficacy with an increased risk of retinal detachment.
There are some retina doctors who perform pars plana vitrectomy for patients with floaters. However, while generally considered a "safe" surgery, there is about a 2% risk of retinal detachment, 1% risk of secondary cataract formation intraoperatively, overall increased risk of cataract formation postoperatively, and <1% risk of endophthalmitis, infection inside the eye. Someone stated above that these are "low." It may seem so looking at the numbers, but in your case this would be an elective surgery. A retinal detachment is a major complication. While it can be repaired, the eventual visual outcome is variable depending on the circumstances. If the detachment does not involve the macula, the area of the retina responsible for your central vision, in many cases vision can be restored to 20/20 - 20/40. Some patients only regain 20/50-20/200 vision. A small amount of patients are only able to visualize hand motions or can only perceive light. The outcomes are even worse for RD that do involve the macula. The surgery itself can also either cause cataract or accelerate cataract formation which can require an additional surgery to address. And while the chances of it occurring are very low, getting an infection inside the eye can be catastrophic, oftentimes resulting in severe visual impairment even with appropriate treatment. Any time you perform intraocular surgery you run this risk. LASIK or PRK only address the cornea, the front of the eye which means that getting an infection is much milder and is limited only to the ocular surface. Other complications of vitrectomy are macular edema or epiretinal membrane which can affect your vision just as badly and possibly more noticeably the floaters.
Vitrectomy overall is considered a low risk surgery, but generally that is in the case of a patient with a retinal detachment who runs the risk of losing vision without the surgery. In your case where you are likely 20/20 with a condition that has a benign course, the risks generally outweight the benefits unless you are experiencing severe visual debilitation as a results of the floaters.
The tldr version: Don't get the laser or the surgery unless the floaters are bothersome to the point where your activities of daily living and quality of life are severely impaired.
My public service announcement: If you suddenly experience a new floater associated with any of the below symptoms:
1)flashing lights
2)a shower of many floaters, i.e. 50-100
3)a dark curtain dropping over your vision
Although the risk is generally low, these symptoms in the context of a new floater can signal a retinal tear or detachment and you should be seen by an ophthalmologist as soon as possible.
dennilfloss
Past Lifer 1957-2014 In Memoriam
Oct 21, 1999
30,509
12
dennilfloss.blogspot.com
Here's a trick having to do with currents in your eyeballs, looking up then down will displace floaters out of your field of vision more than looking left & right.
silverpig
27,703
11
My dad had the same problem and his doctor said his retina was about to detach. They used a laser to weld it down around the edges. He then got the same problem in the other eye at the same time, so had the other one done too. He's fine now and the floaters are gone, but it is a serious problem.
