INFO: Linksys Wireless B setup
ROJAS
I was given a wireless B Linksys router. I do not have a setup cd. If all I want to do is connect my dsl modem to it and then connect 2 pcs is the setup cd required if all I want to do is surf the internet.
I don't want to change any settings, just run defaults. I'm using Windows Xp Pro.
Thanks
coolred
4,911
You should be fine without it, as long as nothing needs to be changed and there are no special needs, then it shoudl work out of the box.
