Infinite loop on XP. Has anyone pinpointed the problem device?
Spike2000
Hello,
Quick follow-up on the Infinite Loop problem on XP. I've heard so many opinions on what is the source of this problem. Are there any conclusions to this. I would REEEEEALY love to find the source of this so I can replace the hardware in question. I feel like I've tried EVERYTHING!! Here is my config, Please shoot me any recomendations on what to get rid of:
ASUS K7M Slot A MB
Athlon 600
Gforce (Leadtek) 256ddr
640 meg ram (Kingston I believe)
I believe the prob to be with the Gforce drivers...But I 've tried them all & it doesn't fix it!! Always get the "Send error rpt to Microsoft?" mssg (referring to Video)
or
a spontaneous reboot while surfing the internet or playing 3d games!!
ahhhhhhhh!!!! Please help What can i REPLACE????
AS ALWAYS THANKS TO ALL!!!
RP
What are you doing when your computer goes into the loop? I'd suspect sound card drivers or settings. I used to have the loop when I played Counter-Strike, and it turned out that I had 3D sound enabled, which would cause the computer to loop after like 15-30 minutes of gaming. Now that I've turned it off, everything seems okay. Hope this helps.
