Hi all. This is a follow on from this thread:
http://forums.anandtech.com/showthread.php?t=2187972
I've been seeing for a couple of weeks weird voltage drops (and occasionally spikes) as well as odd temperatures. The sort of voltages I'm seeing are:
Vcore: 1.34V High, 0.20V Low
VIN1: 1.01V High, 0.01V Low
AVCC: 3.41V High, 0.03V Low
3VCC: 3.39V High, 0.05V Low
VIN4: 1.00V High, 0.01V Low
VIN6: 1.91V High, 0.01V Low
VIN5: 0.01V High, 0.01V Low
in HWMonitor. What usually seems to happen is that I'll have all those readings without the VIN5 reading, and that VIN5 reading will pop up at the same time everything else drops through the floor, only for a fraction of a second. With HWMonitor off, I'm also getting occasional logs on Asus' AISuite of drops (12V down to 2V, for instance) and spikes (VCore up to 2V for a moment, 5V up to 8.5V) and weird temperature drops and spikes (Chipset from 30C to 127C for a fraction of a second, CPU from 35C to -40C). I initially started looking at the PSU, but after adding a UPS with AVR to smooth out our crappy power, and measuring voltages on the PSU directly and then, to be sure, swapping in a different PSU, I'm still seeing the same symptoms. I haven't yet measured any voltages directly on the board, and had a look last night to see if there were any obvious points to measure on. I didn't see any (what there is must be undocumented, unfortunately). This is really weirding me out, any suggestions for what may be going on? I'm completely at a loss.
