Index.php not resolving(?)
testera
I'm not sure if "resolving" is the correct term but I have an index.php file in my public_html directory and it doesn't display the page when I go to the site.
What could be the issue?
I added a test index.htm file to the same directory and it did display when I went to the site.
Any clues or suggestions?
I forgot to mention that I just transferred (or tried to) transfer this site from one host to a new host. Maybe my transfer didn't work properly...but the index.php did transfer.
Thanks.
What web server are you running? Try fully qualify the page first (www.mywebsite.co\index.php) instead of just the site (www.mysite.com). If this works, you need to change the site to default to index.php instead of index.htm or index.html. If that doesn't work, then you site doesn't support PHP. Not all of them do.
Embarrassingly I don't know if I have apache+php.
When I load a.php it gives me a page titled,
"PHP Version 5.3.27"
It's a web server configuration issue.
The question is do you need a dynamic index page?
Just put in a redirect in the index to your index.php which can be named whatever you like.
