Increase in speed/signal by using only 802.11g instead of mixed?
arh2o
I have a Zyxel X-550 and a MSI PC60G adapter. They both support a,b,g, and right now my router is set to send out "Mixed." If i set my router to only send out 802.11g signals, would I be getting better speeds and more signal?
Also does enabling TX bursting in the Ralink wireless tool have any effect on speed?
In general it does nothing.
However if all the system is (example) 802.11g and for unkown reason the system works at 802.11b, or very lower rate of 802.11g, in rare occations forcing it to maintain the standard might help.
The good news is that it does not "cost" anything to try. 😉
Theoretically, A isn't faster than G. It's the same max throughput of 54Mbps. That said, it does use the less crowded 5.4Ghz frequency so it's range is better and you do tend to get faster speeds due to the better/stronger signal.
You shouldn't see any speed difference with G devices if the router is set to mixed or not. You would see a decrease in speed if you are using B devices at the same time though.
Wireless, in general, is very distance and location dependent. For G networks, if you are getting 10 to 12 Mbps you are doing pretty well even under optimum conditions. If you are getting a lot less than that you can try these things:
First: Test the speed of your wireless network by having your PC and router in the same room. If you don't see an increase in speed, you simply aren't going to see any better on that hardware.
If you do see an increase in speed by having them closer together try these:
-Change the "channel" that your router is using. There could be interference on the default.
-Reduce the distance between the router and your PC
-Move the router so that there are as few physical obstructions between your PC and it.
-Make sure that your transmit strength on the router is set to maximum, if there isn't an option on the router to do that, you might be able to use 3rd party firmware to boost it if your router supports it.
-Try using hi-gain antenna on the router.
None of this will guarantee a faster connection, but often do help.
If they don't work you can try using a wireless extender/access point or Try using just the A network if all your hardware supports it.
If you are already getting 10Mbps or better then you simply aren't going to do much better on a G network. At that point your only option is to move up to N.
Theoretically A IS faster than G because of more efficient modulation. In practice it IS faster than G provided there isn't too much attenuation or dense material to go through.
Also it is well known that G is faster than mixed mode in theory and practice. This is fact. G only means only OFDM modulation will be performed instead of also doing B modulation, this is more efficient than B and this leads to better overall throughput, provided there are no b clients anywhere in the wireless cell, if there are performance drops dramatically. This is why it's best practice to take advantage of the higher throughput/performance of G and force it to G only.
These are normal values:
-----------------data rate-----throuput
802.11b -----------11----------6
802.11g (802.11b clients in cell) -----------54------ 7
802.11g (no 802.11b clients in cell) 54 22
802.11a 54 [/b]25[/b]
So A only = 25 Mbs thruput
G only = 22 Mbs thruput
Mixed with a b client anywhere near you = 7 Mbs
For "G Only" mode to be faster, there can be no "B" clients visible to the AP. Any B client that the AP sees will bring it down to "mixed" performance levels.
even if the AP is set to use G-only?
If the AP is set to parameters that would only recognize G clients, then it shouldn't downshift.
That may restrict the available speeds and the preamble, which would also likely reduce the usable distance, since the higher data rates don't work for distance.
One of the reasons for keeping B active is that it has (tends to have, chipset variable) longer legs than G.
