Incorrect Icon for Jpeg Images
Hey all,
I had to reformat my HDD and reinstall everything due to a virus or corrupted system file. Anyway, now that I have reinstalled Photoshop CS2 the file icons for jpegs should be changed to a PS icon. However, I cant get this to happen. I have corrected the file associations so they open in CS2 but it didnt change the icons. They still show up like they did when they were associated with Windows picture/fax viewer.
Anyone know what I can do? Its not a cricital issue but its certainly buggin me a bit.
Thanks.
open windows explorer, click on tools > folder options. click on the file types tab. find the type you are looking for (JPG) and click on the advanced button. then there should be a button for change icon. it will probably have the correct dll to get the icon from, but if not you might have to browse around, for me the jpg image is in the shimgvw.dll file. you can also select another image if you choose (dll's and exe's can have icons to choose from)
