I have been reading the reviews for several cards on Newegg.com, specifically for 3850 and 4830 cards, and there are mixed reviews regarding the fan noise. Half the reviews say its quiet, the rest the fan is too loud even on the slowest speed.
Could this be a manufacturing defect to have such a high variability - or could this be a result of the user's cases? These fans seem quite small, and would not move alot of air. So to me, it seems they would be susceptible to pressure difference in airflow in the case. If there is a slightly lower pressure than "optimal" the fans could be screeching because the fan is motor is working harder. For instance, if someone has a side vent fan set to eject air from the case, it could create an airflow over the card that disrupts the fan, or less than standard pressure if airflow into the case is not good. Basically - image a venturi tube and the tube is the little sliver of space that the graphics card take up in the case that now has a fan inside of it, especially if the card has another PCI card underneath it making airflow to the fan more difficult.
Anyway - I am hoping to keep my case quiet - I am not playing hard core games, and I am hesitant of getting a card that some say is loud even at idle. But, I am using an Antec 300, so I have some options to adjust airflow.
