I have a motherboard with integrated graphics and an empty PCI Express 16X slot. It conforms to the PCI-E 1.0a standard. I am planning on adding a discrete videocard soon. As all the new cards are now PCI-E 2.0 and this is supposedly compatible with earlier versions of PCI-E, I had assumed that a new videocard would be compatible with my motherboard. However, I found out that things are not so simple.
First, I accidentally found this on the Wikipedia NVidia 8 Series page:
Shortly after the release, an incompatibility issue with older PCI Express 1.0a motherboards was unmasked. When using the PCI Express 2.0 compliant 8800GT in motherboards with PCI Express 1.0a slots, the card would not produce any display image, but the computer would often boot (with the fan spinning at a constant 100%).(...) In relation to this compatibility issue, the high numbers of DOA (Dead On Arrival - cards that are broken out of the box) (As much as 13-15%) were believed to be inaccurate. When it was revealed that the G92 8800GT and 8800GTS 512Mb were going to be designed with PCI Express 2.0 connections, NVIDIA claimed that all cards would have full Backwards-Compatibility, but they completely failed to mention that this was only true for PCI Express 1.1 motherboards.
Looking for confirmation, I found more info on XBit Labs:
First, in their review of the 8800GT:
Although PCI Express 2.0 cards are compatible only with mainboards with PCI Express 1.1 and higher, our GeForce 8800 GT worked on an ASUS A8R32-MVP Deluxe (ATI CrossFire Xpress 3200) which only supports PCI Express 1.0a
So they noted an exception to the incompatibility issue.
Then , they touch the subject again in their review of the 3850 and 3870:
Like with Nvidia GeForce 8800 GT, we can expect some incompatibility with certain mainboards supporting PCI Express 1.0/1.0a. The lack of such problems is guaranteed for PCI Express 1.1 mainboard only.
When they reviewed the more recent 9600GT though, X Bit Labs didn't mention this potential issue.
I would like to know if some of you have found more info about this issue, as the only workaround mentionned seems to be to reflash the videocard BIOS, thus voiding the warranty.
Do you have experience with installing a PCI-E videocard on a mobo only supporting PCI-E 1.0 or 1.0a?
Thanks
Thanks
