In need of decent PCI-E card
LMR
11
Any recommendation? I ran out of PCI slots and I'd like to utilize these PCI-E slots..
Thanks in advance!
Zepper
18,998
Neither of those need the thruput of PCI-e, so it's unlikely you'll find one.
Perhaps you could get one of those adapter cards that makes two PCI slots out of one.
.bh.
shortylickens
80,287
17,081
Damn. Leet beat me to helping a newb.
The only other thing I can think of is, exactly how many slots do you have available and how are they being used?
We may be able to figure something out.
Also, I do believe I've seen multi-port gigabit ethernet adapters of a PCI-E variety. Obviously not in wireless format. Does it have to be wireless?
Madwand1
3,309
You can get single port GbE PCIe adapters, and these do perform better than PCI ones, although it will often take good drives / RAID (on an internal LAN of course) to see the difference. (But if you have a crowded PCI bus, esp. with an add-on storage controller -- then the difference might be easily noticable.)
Another option would be USB -- USB wireless would probably make more sense than PCI / PCIe, and USB sound is also widely available.
