Question In Multi-Gpu scenario, Primary GPU always performs better than secondary GPU
sunilennaseril
4
In my software, i have a functionality to playback of images. This playback needs to maintain 30 fps.
My machine has 2 AMD WX5100 GPUs with 2 monitors connected to each GPU.
When one of the monitor is made the “Make this my main display” from Control Panel\All Control Panel Items\Display, then this GPU becomes the primary GPU and the other GPU becomes the secondary GPU.
After this when i playback the images in both the monitors, the monitor connected to the primary GPU gets 30 fps playback, whereas the playback in the monitor connected to the secondary GPU gets only 24 fps.
Now if the main display setting is reversed, the performance will also be reversed.
Why is this performance difference based on the primary and secondary GPU. Please help.
VirtualLarry
56,587
10,227
Checked the monitor refresh rate under Display Properties , Advanced , Monitor in Win10?
davide445
132
11
What's your motherboard?
In standard mobo the second PCIe slot does have lower bandwidth than the primary one (normally PCIe 3.1x4 instead of 3.1x16).
This result in most cases in a 5% drop in performances, but still
Edit: reading better your post: this cannot be the problem if the behavior is symmetric!
sunilennaseril
4
Yes i had checked the motherboard specs
https://www.dell.com/support/manual...b5135f-5063-4cc3-a667-c999fe06dc70&lang=en-us
I had used the slots marked [3] & [5] in the pic shown in above link
