Originally posted by: jmatej
I am struggling to find a system that doesn't heat up so much. I am not an overclocker. I currently have a athlon xp 2200+ on a Gigabyte 7AXP mobo. Large antec case with enermax 450v power supply and two 120mm fans (front and back). My CPU quickly rises to 65C with virtually no activity (system temp around 37). The setup is fairly noisy as well (fan noise). I have gone through a couple of different heat sinks ( the latest is a heavy cooper with fan) and I am not getting much progress. I f I want a cool and quieter box (like those Dells), would intel chips be the way to go? I am under the impression that at similar performance levels, amd chips generate (and tolerate) more heat.
First, remember this: heat does not equal temperature. If you put your CPU and cooler on a different motherboard that is calibrated differently, it might read 42C instead of 65C. The actual heat production hasn't changed, it's just what the motherboard is
calling it that's changed.
Secondly, your AthlonXP 2200+ generates a maximum of 63 watts, according to
Sandpile.org. By comparison, upper-end Intel processors are in the 80W-100W+ range.
So my suggestion is to
1) stop worrying about your motherboard's temperature reading
It's a Gigabyte board, k?
2) make sure your heatsink
is installed properly (guide
here) using high-quality thermal grease
3) if you want a quieter heatsink/fan unit, get a Thermalright SLK-800A and a Panaflo L1A 80mm 12-volt fan
4) if you want an upgrade, get a retail-boxed Athlon 64 and enable its Cool 'n Quiet feature if you like. They run cool to start with, and with CnQ enabled they will also downshift to 800MHz when idle or lightly loaded, at which point their thermal output is around 35 watts
