In deep shit..help plz
EvilComputer92
1,316
I have a a Linksys BEFW11S4 (v2) Wireless Access point, which i plan to connect to my xbox live connection(once my subscription card comes from newegg) thru a WET11 Wireless Ethernet Bridge. Now it says right here. that the router I have is incompatible with xbox live? Did I just burn $50 for nothing? Or is there some kinda workaround for this. Or is microsoft just giving me some crap. plz help quickly
thx
ultimatebob
25,134
2,450
Looks like something pretty simple to fix... just update your router with a Firmware level that is considered "XBox Live Compatible" you should be able to find the right version on Linksys's support section.
