Hi there,
New guy posting here although long reader of Anand.
I'm moving into a new place that is pre-wired for sound in every room. I'm somewhat of a nerd when it comes to audio and I'd love a true home theater setup, but with only one main living space, I won't be able to have a huge setup. In-ceiling/wall aren't exactly the best quality money can buy... I may install ceilings in the other rooms, but for now, just trying to figure out the living room/makeshift home theater...:
There aren't any speakers actually installed, just wall plates, so my dilemma is whether to actually install ceiling speakers above where the couch/TV will go, or to just let the pre-wiring go unused. The back wall is wired for rear speakers, and I don't think we'd change the setup of the room, so those technically could work as they're more than 4-5' away from the back of the couch.
Do I use a center speaker + two front facing L&R like a B&W CM1 (http://www.bowers-wilkins.com/Speakers/Home_Audio/CM_Series/CM1.html - out of my budget but something similar) - and then use the ceiling speakers as a Left&Right surround hookup? Then I'd use the rear speakers as well - which would give me a 7.1 setup.
At the same time, I'm not sure if ceiling speakers would just sound weird in terms of a 7.1 setup, since I'd have direct sound coming from the front and back, but the sides wouldn't really be sides, they'd be ceiling.
My other option is to forget the in-ceiling/in-wall rear, and just get a really solid center speaker and bookshelves like the mentioned CM1's. Then only use the ceiling speakers for music listening, not movie/TV. For some reason, I feel like since the place is pre-wired, I shouldn't waste the opportunity.
Any insight would be greatly appreciated, I don't want to mess this one up and then obsess over my shoddy setup. Thanks!
