Ive been trying to do a backup image of a node on my home LAN to my servers HD but when i run the bootdisk which i created with Imagecast using the DOS drivers off the FA312's driver disk it will not communicate with the server
Ive tried using both DR DOS and also supplied Imagecast with Win98 boot files etc but no change.
The node is connected to a switch which has a standard UTP cable (not crossover) connected to the uplink port (uplink button engaged) which runs upstairs to my server via a hub. This uplink cable is plugged into the uplink socket on this hub, but the uplink button is not engaged as only one of them needs to be active to create the crossover for the uplink yeah?
Seems strange how i can browse this PC fine, and transfer files no prob, but Imagecast over this network link is a no go!
Ive tried drivers for (any) Netgear nic, and also NE2000 compatible but still no go.
Could the cause of this be the FA312 nic? as my other PC's using D-Link 530tx's have no such prob! hmmm? I aint got a spare nic at the moment so trying another is a non starter until i get hold of another.
If anyone can offer me some advice for getting round this prob would be a great help
thanx,
rockhard =)
thanx,
rockhard =)
