iMac connection to NEC PA241W-BK
nyrog
4
Hi all,
Purchasing the NEC PA241W-BK monitor & want to connect to iMac 21.5", mid 2011 model. The iMac only has 1 Thunderbolt port. The NEC monitor has DisplayPort, DVI-D (2), VGA 15-pin D-sub ports. Can someone tell me the best method to connect the two? Thanks for your help.
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
I would get a TBolt to DisplayPort or TBolt to DVI adapter, whatever is cheaper from monoprice.
