Im using CSAA + FXAA ?
tweakboy
9,517
www.hammiestudios.com
Hey guys thanks for the help... When this FXAA option came in the 301.xx series I turned it on. But do I also use CSAA. So you supposed to use both ? or do I use 8x and no CSAA and turn on FXAA.... hmm ?
thx
Grooveriding
9,147
1,330
hey guys thanks for the help... When this FXAA option came in the 301.xx series I turned it on. But do I also use CSAA. So you supposed to use both ?
thx
I would only use FXAA if you cannot get playable frames with true antialiasing: MSAA/CSAA etc. Otherwise I would leave it off. Post/shader AA sucks the big one and is not of the quality of true AA.
BFG10K
22,709
3,005
You can use both if you really want to, but there's generally no reason to.
