Im out of THERMAL grease! QUESTION????
BmXStuD
1,474
Since that. Would it be ok if i took off my old cpu and take the thermal goo off that w/ a plastic bag and spread it on my new one. True that a cpu that had the grease on it still has it on it and wipe-able when you remove it from the socket? :p
BmXStuD
1,474
Originally posted by: boyRacer
i don't know if you'll have enough... :D ...but you might as well use toothpaste... ;)
Question would toothpaste work rofl?
BmXStuD
1,474
Also i make it enough b/c u only need a small amount right.
boyRacer
18,569
Well according to this... just about anything works... :D ;)
But if i were you id make a quick trip to a close radio shack, fry's, compusa, or bestbuy... if i didn't want to wait. I'm not gonna burn up a new proc unless i got it for free. :)
BmXStuD
1,474
Thing is i have no ride up to any of the stores. Radio Shack is really close but they dont sell it anymore @ that one and its bout to rain like hell.
BmXStuD
1,474
Originally posted by: shady06
anything really does work, the generic stuff i i used had the same temps as AS3
Yes, did you read what i said and how i was going to obtain the grease?
herei go again
"Would it be ok if i took off my old cpu and take the thermal goo off that w/ a plastic bag and spread it on my new one. "
Apr 17, 2003
37,622
actually, i was just agreeing with boyracer. to answer your question: IMO, it's possible to do that but i would only do it as a last resort
pm
Elite Member Mobile Devices
Jan 25, 2000
7,419
22
It takes very, very little thermal grease to make things work. Too much is worse than too little.
BmXStuD
1,474
So does that mean "YES" i can do what i'm question ing bout?
boyRacer
18,569
Yes... but don't kill me if something goes wrong. :D
BmXStuD
1,474
I WILL HAUNT YOU DOWN IF MY PC FRYS. j/k buddy
BmXStuD
1,474
Ya less than i week also 1 would be able to get the real stuff would this work as temp.
McMadman
938
I've done this, and i've seen cpus run just fine without any TIM between them (of course things do run a little warmer)
everman
11,288
I'd wait to get fresh compound. and certainly do not attempt to operate it without any thermal compound!
