I'm out of ideas - Help please!
Sidekicknichola
425
Due to a recent move and the fact my wife hates seeing wires, I can no longer hardwire my main desktop pc.
I'm running a TP-link PCI wiresless card (TL-WN851ND) with the most recent drivers, and Tenda W368R wireless router (300 mbps N) with 90% signal strength
When I run a speed test from my laptop (Dell E5430) I get:
Ping - 6 ms
Download -35 mbps
Upload - 42 mbps
When I run a speed test on my phone (GS4)
Ping - 8 ms
Download -22 mbps
Upload - 36 mbps
When I run a speed test on my desktop
Ping - 4 ms
Download -11 mbps
Upload - 13 mbps
** All tests done from the same location in our place**
I've tried a different PCI card, a USB wireless adapter, and a different router..... not sure what else can be done.
Any idea what on earth is the reason my desktop is so much slower than everything else?! .... or what I can do to help improve my speeds?
VirtualLarry
56,587
10,225
make sure that you are using WPA2-PSK (AES) and that WMM is enabled. Otherwise, connection might fallback to "G", whch your numbers support.
SecurityTheatre
672
Ping - 6 ms
Download -35 mbps
Upload - 42 mbps
Ping - 8 ms
Download -22 mbps
Upload - 36 mbps
Ping - 4 ms
Download -11 mbps
Upload - 13 mbps
Are you using 5GHz wireless? It's enormously faster than 2.4Ghz.
Sometimes 2.4Ghz interference can lead to instability in performance like this.
JackMDS
29,553
430
Where the Antenna of the Desktop is physically located?
:cool:
Sidekicknichola
425
Should be, I'll have to confirm tonight when I get home.
Back of my case (PCI card), corner of the room but 12" from any wall or structure, on top of the desk.
seepy83
2,132
It's been a long time since I've used a desktop with a wireless card, but I used one that had its antenna on a cable (like this) so that you could locate the antenna away from the desktop's chassis to get a better signal. I have no idea if the card I linked to is any good, but you might want to look into something like that.
