I'm looking for some sort of way to Store incoming fax's in my PC and not to print them.
necro007
1,002
Hi,
I want to be able to send fax's from my PC and when i recive a fax, i want to be able to store it in my PC BUT i don't want to print it out.
I'm trying to run a paper-less office, so if i can cut this down it would be a big step.
Thanks for your help.
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Most fax S/W will do what you are asking.
Inbounds are stored as a document; print it as desired.
Outbounds may be able to have a copied saved (depends on the S/W used)
DarkTXKnight
933
what is some good free or cheap fax software that will do this? Ive been tyring to get rid of my multifunction machine for some time and if I can get something that does the faxing on the PC Id be set.
EagleKeeper
Staff member
Oct 30, 2000
42,589
WinFax used to be the standard.
XP has fax S/W built in.
Most fax modems that you can buy will come with a S/W package.
Smilin
7,357
mmm, used to be free fax software for this built into your Windows OS.
Saves files as .tif or something if I remember.
Genx87
41,091
513
US Robotics 56k Modems have a fax app that ships with it that does this. When Faxes are sent and recieved they go into the in and outbox. You can save them in any format from there.
