- Mar 4, 2011
- 11,395
- 1,189
- 126
Are pulleys straight an unexplained miracle?
How does some piece of crap WHEELS actually REDUCE the force? That makes ZERO sense to me. What's actually picking up the slack??
I have to lift this 100kg rock. If I add some facking WHEELS, then SUDDENLY those wheels provide sudden power out of thin space and make it liftable with just 25kg.
What the hell powered 75kg? Is there a combustion?????
I mean, is this a cheatcode? Why make anything outside of this cheat? Why don't you have a child lift empower state building because all you need are these MAGICAL FACKING PULLEYS. Just throw 83743847 pulleys at it and you'll gain infinite power.
I don['t know if it's because I'm high I'm not getting it or I knew it before how pulleys worked and now failing to understand.
