cardshark828
A couple of days ago I got another GTX 460 to run in SLI with the 460 which I already owned. Since installing the card, I am finding that the top card inevitably hits 100c when gaming. When I have the fan speed on the card set to 100%, it still hits 100c. I believe this is an airflow issue rather than a problem with the cards, as when I run either card alone they run at normal temperatures. I have the cards installed in the dark blue PCI-E 2.0 slots on the board. There is another white PCI-E slot at the bottom of the board, but neither card will fit in it as my PSU obstructs it. I have a Coolermaster HAF 922 with only the 3 case fans that come pre-installed with the case. There is room for 2 extra fans at the side and bottom.
Is it likely that adding extra fans would be enough to keep the temperature down on the top card, or should I really be looking at getting a new, bigger case like the HAF-X? It's a pity about the temperatures, as I'm very satisifed with the performance increase compared to a single 460.
Thanks guys for any advice you can offer.
