Hello
I'm having problems with an Edimax EW-7612PIn wireless PCI-E card.. it's on a PC with Windows 7 64 bit.
I can connect to the home network router (from the ISP) and surf the net and download data (games on Steam etc) and it NEVER disconnects me etc.. but sometimes they will be a sudden drop in speed and then after a few minutes or so it rises.. the normal speed for us is about 520 KB/sec but I don't always get this.. I'll mention a few things to here:
I use other machines (laptops) and I ALWAYS get over 500 KB/s ie top speed.. it doesn't have the drop outs etc.
I always use sites like Nvidia (for drivers) or Oracle (for Java JDK) as TESTS for speed.. again when I use OTHER machines in the SAME house the SAME router/ISP and same websites/download file the speed is our TOP speed ie over 500 KB/s.
I DID move the position of the antenna connected to wireless card and it DOES make a difference it can hit that top speed for some time.. it is BETTER but not PERFECT like the other machines.
I also discovered that having the antenna in close proximity to USB 3.0 cables slows the speed down.. I have external hard drives (via USB 3.0) and when I switch the power off to them.. the downloading speed
jumps up in an instant.
I have when having these sudden drops in speed.. tested different apps.. for example downloaded a file using Firefox and then Steam and then GOG.com downloader and they ALL had the same slow speed.
I have got help from some PC manufacturer who say it seems like a DRIVER ISSUE.. and I should update the drivers etc.. I think this seems correct as the PC can sustain those high speeds for some time but has these dropouts in speed from time to time.
I have downloaded/updated drivers and am monitoring the situation to see if it helps but I have general questions about DRIVERS.. when you're updating/replacing drivers can you install OVER existing ones (for any hardware)?
If the driver file/setup program is being run.. will that check to see if the driver matches the hardware etc?
If anyone has any suggestions and ideas then please let me know?
Thanks in advance.
Thanks in advance.
