Octavarium
Well, I'm working on a new build right now, and I figured some non-stock cooling might be nice to have. So, I purchased the Arctic Cooling Freezer 7 Pro on the internet. It's supposed to fit LGA775, and I'm running an LGA775 processor. When I went to install it, I found that the black and white plastic pins to secure it seemed to be too far apart. I can only ever get two in at the same time (they both have to be on the same side) and if I push one from the opposite side in, the pin diagonal from it comes back out. So, I tried it again with the stock heatsink/fan and had the exact same problem.
I returned the motherboard, as it was a cheapo one, and bought another, highly rated, more expensive one. The only problem is, I'm having the same exact problem. I find it highly unlikely that I got two bad motherboards. Is there a common problem, or something known I might be doing wrong?
