I'm going to start saying Twenty Oh Three instead of Two Thousand Three
Triumph
14
It's more "futuristic" to say Twenty Oh Three. No one in Star Trek says Two Thousand Three Hundred and Thirty Four. And no one ever said "Nineteen hundred ninety three", so it's more inline with what we're used to saying anyway.
pulse8
20,860
That's fantastic!
Corn
6,389
29
Wearing tinfoil jumpsuits is also more futuristic.
Migroo
4,488
9
Actually the correct English is:
Two Thousand and Three.
All you Americans are forgetting the 'and'! :D
illusion88
13,164
im down with that
Triumph
14
But nobody ever said "Nineteen Hundred and Ninety Four! I'm just trying to be consistent.
XZeroII
12,572
Actually, it's Two Thousand Three. The 'and' only comes into play when dealing with a fraction or decimal. Like Two Thousand Fourteen and Five Sixteenths.
bigredguy
2,457
Actually saying 'and' in a number sequence designates a decimal. Two Thousand and Three = 2000.3
Kyteland
5,747
No, Two Thousand Three is proper. the use of an 'and' signifies a fraction. If you write a check (or is ir cheque for you?) you do not put an 'and' between any of the actual numbers. You put it between the dollars and the cents.
EDIT: Sigh. Too slow again.
Insane3D
19,446
Yep.
For instance..
107 = One Hundred Seven not One Hundred and Seven.
LeeTJ
4,899
actually, some did say nineteen hundred . . . , what they didn't say and more appropriate for your example is they never said year one thousand nine hundred . . .
ohtwell
14,516
9
You could always include the use of "stardate"! :D
Today is Stardate 021703. :p
: ) Amanda
