Im going to get a reciever for my Klipsch 5.1's, what should i look for? DTS Decoding? etc etc
5489
2,163
im looking for a cheap reciever, best buy has a KHL reciever.
PRODUCT FEATURES
500 watts of total output: 100W x 5 @ 8 ohms, 1kHz, less than 1% THD
Built-in Dolby Digital and Dolby Pro Logic decoding
6 DSP modes: Concert, Theatre, Church, Arena, Stadium, Club
Digital AM/FM tuner with 30 station presets
2 digital audio inputs (1 optical, 1 coaxial)
3 S-video, 4 A/V and 3 stereo audio inputs
1 S-video, 2 composite video and 2 stereo audio outputs
Bass/treble control
Headphone jack and speaker-on/off control
2-color fluoroluminescent display
Unified full-function remote
PRODUCT DETAILS
R-5000
Front Surround Power per Channel
100W x 3
Rear Surround Power per Channel
100W x 2
Total Harmonic Distortion
Less than 1%
Station Presets
30
Dolby Digital Decoder
Yes
DTS Decoder
No
Dolby Pro Logic Decoder
Yes
Simulated Surround
No
DSP Soundfields
5.1-Channel Input
Yes
Digital Inputs
Stereo Audio Inputs/Outputs
2/1
Rear A/V Inputs/Outputs
3/1
Front-Panel A/V Inputs
Yes
S-Video Input/Output
3/1
Component Video Input/Output
No
Composite Video Output
Yes
Multiroom Capability
No
Headphone Jack
Yes
Remote Control Type
Standard wireless
RF Antenna Input
Yes
Phono Inputs
No
Preamp Outputs
No
Does this look good?
5489
2,163
i think the amp in my PM's sub is busted.
So im gonna hook up all the sattelites to the reciever, and hopefully the sub to the reciever, if it works.
Goosemaster
48,775
Are you sure...maybe you didn't pug them in correctly or something(no offense intended_
Also....your best optioon is to buy the klipsch digital decoder box that they sell on the website.....THen all you need is a source with optical out
5489
2,163
im positive they're hooked up correctly. i had em for quite some time now. they've been doing funny stuff lately
Goosemaster
48,775
can you return them?
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
How long have you had em?
aphex
Moderator
Jul 19, 2001
38,572
Also..that reciever will blow if not provide a means to easily blow your speakers
The sat's are only meant to handle 60 watts and the reciever your looking at is rated at 100 watts/channel. Also, i dont think it is possible to just hook up the sub to the reciever, then again i could be wrong.
5489
2,163
i always thought that it meant it could handle UP to 100 watts. hehe. so does that mean if i hook up some 120 watt speaker so that, then the speakers will just be used at 100 watts, or would that blow the speakers too.
Thegonagle
9,773
The brand is KLH, not KHL, and I have no idea if it has any bang for the buck, or if it is just garbage. Personally, I wouldn't touch a KLH receiver from Best Buy.
On the low end for receivers, people are giving the Panasonic SA-HE100 much respect (Matsushita electronics is replacing all its Technics branded stuff with Panasonic branded stuff). It's available for about $240 online. I very seriously considering buying one.
You can try using your Klipsch Pro-Media speakers, but don't try to turn them up too loud, or you'll be seeing smoke in short order. You'll probably need to bust into the cabinet of the sub-woofer, disconnect the built in amp from the driver, and solder on some new speaker wire to run directly from the receiver. The way I see it, the Pro-Medias you have are goners anyway , so it can't hurt to try. (What use are they if the built in amp is malfunctioning?) When you inevitably blow those poor little Pro-media drivers, you'll want a decent receiver to run a decent set of real speakers.
Pooteh
503
from what i remember, over powering is better then underpowering. just don't turn them up beyond reason, which would be even higher then the max for the original amp.. which was already quite insane:p
also, theres a warrantee period, why not use it?
if your hooking it up to a computer, software decoders do both dd and dts now days.
