- Nov 19, 2007
- 2,793
- 2
- 0
Ok, I have wrestled with Vista until I've configured it all right, but the one thorn in my side is Vista's update.
It downloads the updates and then will not install them. It randomly says it can't check for updates but when I click on it, it says it has 11 updates waiting.
I have encountered error codes (0x080004005) updating windows defender that have no solution. When I try to change or re-register wauaeng.dll, it gives me an access denied error code.
I can't reinstall the service because when I run the update installer it encounters an "unrecoverable error." Does anyone know how to uninstall and reinstall it?
I recently thought I found a breakthrough when I also enabled the backup service and it started installing, but the problem persists.
Got any ideas? I am sick of this. I've looked at countless sites and I don't need this when I'm already BSODing while overclocking.
