I'm freaking confused. Volume conversion
EyeMWing
Banned
Jun 13, 2003
15,670
According to google, 35 gallons is 4.7-ish cubic feet. I know this is wrong, because I can fit more than 5 1x1x1ft objects into a 35 gallon trashcan.
What the hell?
jagec
24,442
See, this would never be a problem if we used the metric system.
Signed,
Your friendly local researcher:)
EyeMWing
Banned
Jun 13, 2003
15,670
Originally posted by: keeleysam
are you sure you aren't reading 4.7ft^3?
Text
And ft^3 is the proper unit for what I'm asking. I wish to compare the volumetric capacity of a 35 gallon trashcan to a 6x6x6ft box.
EyeMWing
Banned
Jun 13, 2003
15,670
Signed,
Brilliant idea.
35 gallons in liters is... 132.5 liters.
6ft in meters is 1.8 meters.
So, now I'm comparing the volume of a 132.5 liter trashcan to a 5.832cu m box.... And my answer is still totally illogical fitting with what I know from experience
..... Okay, wtf am I doing wrong? Have I forgotten basic 3-d math, and volume isn't calculated by multiplying x*y*z?
EyeMWing
Banned
Jun 13, 2003
15,670
Originally posted by: LoKe
35 US gallons = 4.67881946 cu feet
= 4.7 x 4.7 x 4.7
= 103.823
I don't know. I suck at math.
why the fvck are you cubing something that's already a cubic measurement? I don't need to know it's quantum string theory volume!
Jun 4, 2005
19,723
= 4.7 x 4.7 x 4.7
= 103.823
You must have missed the part where I wrote "I suck at math."
MrPickins
792
What the hell?
Can you?
Just as a reference, this 32gal trash can:
http://www.hutshop.com/8687615813.html
Is only 29.25" x 16" x 16". Seems too small to fit 5 1'x1'x1' cubes.
Edit: It works out to around 4.3 ft^3. Seems google is right.
Fenixgoon
33,595
13,294
Signed,
Brilliant idea.
1) gallon = fluid volume
2) pic of said trashcan?
3) think about fish tanks.. a 50 gallon fish tank is maybe 1ft wide, 5ft long, and 1ft tall
all else fails you could test it yourself. make a 1ft by 1ft square, then extend it 4.7 feet and start pouring :)
Cloud Strife
Banned
Aug 12, 2006
475
1 US gallons = 0.133680556 cubic feet
35 x 0.134 = ~4.69ft^3
5ft^3
In theory, you can't. Sorry. :(
EyeMWing
Banned
Jun 13, 2003
15,670
Signed,
Brilliant idea.
:confused: okay. i'm slightly intoxicated, and it appears that i've somehow mentally doubled/tripled all the dimensions on my reference items and on the damned box. it's a 3x3x3ft box, and the reference ****** that I throw in the trash can is roughly 6x6x6. Now the numbers work out much more like they should.
jagec
24,442
Signed,
Brilliant idea.
No, because trash cans wouldn't come in standard 132.5L sizes.
Still, 123.5L = .1235 m^3 = 4.36 ft^3, sounds like either your 35 gallon trash cans are bigger than advertised, or your intuitive idea of a cubic foot is smaller than the actual, which seems likely based on my own experience with estimating volume, and then doing the actual measurement to compare.
/edit: Bah, I typed 123.5 instead of 132.5. I'm not fixing it. Still, you get the general idea.
MrPickins
792
That was the only part I understood. ;)
Cloud Strife
Banned
Aug 12, 2006
475
= 4.7 x 4.7 x 4.7
= 103.823
Hey, at least you tried.
chuckywang
20,133
What the hell?
I don't think you can, unless you have some of the stuff jutting out.
EyeMWing
Banned
Jun 13, 2003
15,670
Originally posted by: notfred
Originally posted by: TuxDave
Pics of you putting 5x 1 cu ft objects in trashcan.
Haha, seriously. I don't think he realizes how big a 1ft cube is.
read the thread. im a bit buzzed and confused a 6x6x6 inch object for a 1x1x1ft object, and i went ahead and tripled the dimensions of the box (increasing the volume by a factor of.... like 12. or 9. or something. i'd better not find this thread in the morning, or i might have to harm myself)
xtknight
12,974
Does your trash can have a fourth dimension in it? Just ruling out all the possibilities.
EyeMWing
Banned
Jun 13, 2003
15,670
it exists in time, if that's what you're asking.
Mrvile
14,066
Wow you're pretty good at math for being slightly intoxicated.
I might try this tomorrow.
