- Feb 8, 2004
- 12,603
- 9
- 81
Ok so ive been trying to figure out why in vista my sound wont stay at 5.1, it always reverts back to stereo, also whenever i set it to 5.1 and try the sound test it will play for a bit and when it reaches the front right speaker i get a "failed to complete test" message, occassionally CThelper will crash too. This is with Z5500's and an Audigy 2 ZS.
So i disabled the audigy 2 ZS and gave my onboard sound a shot, it works a bit better, dosent crash. However i cant get proper 5.1 to work, its screwy, with everything plugged into the correct color theres no rear speakers, with the colors mixed a bit it works but the rear speakers are really weak, sounds like theyre trying to play what the sub should be playing. So wired up right or wrong it dosent work either way.
MAIN QUESTION
Screw this RCA crap, im gonna use an optical cable, it cant fail with just the 1 cable right? Please answer my questions below:
1. What kind of optical cable do i need? The AC97 has two square looking ports.
2. Whats the difference between the two types of optical cable? If needed i can use both as my 5500 supports both and i have an audigy 2 nx external card that supports both.
3. Will an audigy 2 nx give me the same crap in vista that my audigy 2 zs gave me?
4. Will i notice any sound quality differences in going from RCA direct to optical?
5. Anything else i should know? Anyone see any problems that could arise with this?
MAIN QUESTION
