They don't make the 1.6A anymore so they are harder to find...as far as overclocking when the 1.6A and the 1.8A come out the 1.6A was a much better overclocker but now that they have update the stepping in the 1.8A you can get 2.4Ghz out of a 1.8A chip and some can go as high as 2.8Ghz and with the new C1 stepping ppl are hoping to hit 3.0Ghz
There is someone on the Overclocker forum that have a 1.8A C1 stepping that running it at 3.5Ghz!!! :Q
Not to bad for a 1.8A chip 🙂
Bottom line unless they are guaranting a high oc I would not pay that much for a 1.6a....Most of them at the end did 2.4 at default vcore but like was mentioned above the 1.8as now with bo stepping often can do 2.6-2.7 at default and therefore should offer a beter oc.....
