- Aug 14, 2001
- 12,343
- 0
- 0
I've been working hard at getting all of the design details worked out, and the design is getting fairly close to completion. Once it's done, I'll have it laser cut by Ponoko and will put it all together, mostly using glue, with some other hardware for the removable side panel and of course attaching the computer parts inside.
Features/limitations:
Some pictures:
Will post more details as I make more progress!
By the way, digital calipers are the coolest thing ever, and they're really cheap! Every geek should own some.
- Within a few mm of being as small in height/depth as possible with a mATX motherboard.
- Pretty small in the width dimension too (5.4" / 137mm)
- Uses a Pico-PSU
- Decent airflow -- 2x92mm fans, airflow straight from bottom to top (also, no conventional PSU to deal with)
- Large dust filter on bottom (much larger than the fans, so it clogs up more slowly and impedes airflow less)
- Enough room for a larger-than-stock, pretty quiet cooler (Scythe Shuriken rev. B)
- Designed for a slim optical drive (normal 5.25" drives are stupidly large)
- Room for one 3.5" drive and one 2.5" drive
- Optical drive and 4 usb ports on front (and nothing else)
- Power button on back
- No room for any PCI[-e] cards
- Will be running an i3 with 8GB RAM
Some pictures:
