Im back, yes with the same problem
Evdawg
979
So if anybody remembers me getting flamed out my a$$ for overclocking my 6800gt and then rma'ing it.
Well i sent in the card, and naturally it came back with a new card. I hooked up the new card friday night, ran it on HL2 and it was fine. Saturday night after work i come in and my sisters told me it was acting goofy (randomly shutting off while playing sim2) so it scared me, knowing this was the start of the problem last time. Immediately it started giving me artifacts and problems again, then i couldnt get past windows once again and running off of no drivers right now. Well since this proves that overclocking was not the problem on my last card, what is the issue? What's causing this? I'm really at a loss and dont know what to say. I can't think that its my motherboard...
P.S. yes i did reset my cmos to make sure everything was default
edit : flame thread
imverygifted
1,368
that really sounds like a bad graphics card, throw it in another machine and see how it works
Killrose
6,230
8
What card were you running while waiting on the RMA? Maybe your PSU is not good enough, that would explain the crashing, but maybe not the artifacts. Try using one of the other DVI ports maybe?
Maybe you RMA'd a perfectly good card and it was something else in your system all along, LOL!! :shocked:
Evdawg
979
if its the psu, why did it work for... about 6 months no problems then go down hill?
Acanthus
19,915
ostif.org
You didnt mention that, posting all the details in one thread would be nice.
Do you have a working PCI-E lock? running the PCI express slot out of spec can kill cards as well.
Evdawg
979
well why would i list that detail if i know thats not the problem?
my board doesnt have a pci-e slot.
Acanthus
19,915
ostif.org
Sorry PCI/AGP lock then.
Evdawg
979
agp/pci lock is the agp bus speed right? default is 66, and on my board you change it to 67 correct? its at 66, default.
Keysplayr
21,219
56
It's the PSU ya big dope. :) Same thing happened to me and also to my best friend. The strain of having a GT on your PSU is not a light one. It can cause an otherwise perfectly functional PSU to a premature demise. Do a test. Unplug anything you don't need in your system. EG CD rom drives, fans, lights whatever. And see if it still happens or at least less often.
Killrose
6,230
8
BTW, what is your PSU? And maybe you could set your CPU to stock settings to take some strain off your PSU while you trouble shoot your vid card problem :)
Evdawg
979
im at stock everything right now. my psu is the Antec 350 (the one that comes with the lanboy)
i still dont think its the psu cause of the artifacts i get... maybe im wrong?
m21s
775
A buddy of mine was having the same problems.
I told him it was his power supply....he told me i didn't know what i was talking about.
He eventually bought a new one...now he has no issues.
I think it is your PSU.
my .02
Evdawg
979
ok thank yall so very much.. i will try it.
its just hard to think of artifacts and a psu in the same sentence.
Evdawg
979
yea well they said they would test the card once they recieved it, so thats why i figured the card actually was bad when i got a different one back.
Navid
5,053
Use a Volt meter and measure the 12V rail voltage on an unused Molex connector while running ATItool "Scan for artifacts".
Run it for 20 minutes and keep monitoring the voltage.
Then, report the results.
If the 12V voltage never dropped below 11.6V, your PSU is not the problem. If it did, it may be the problem. If it dropped below 11.4V, you definitely have a PSU problem.
Evdawg
979
im actually gonna do itthe easy and pick up a psu from best buy here in a bit ;)
Navid
5,053
Why?
How do you know it is the PSU?
What if you get a new PSU and the problem persists? How would you know that both PSUs don't have the same problem?
Killrose
6,230
8
The 350watt Smart Blue is a solid PSU as long as it is working. I've got one running a Barton mobile @2.4gig with a 6800Ultra and not much else, but it works fine.
Use a motherboard monitoring programm and take some readings. Also for grins remove one of the mem modules and check it. Substitute the other one back in if the problem persists. Also, did you try re-installing DX9c?
Evdawg
979
Why?
you think two different PSU's, different power, everything are going to have the same problem? I dont. If the same problem persists i will resort to another issue, not the PSU.
Navid
5,053
Why?
Sounds like an expensive way to figure out if it is the PSU or not. You can get a digital Volt meter for $19.99 from Sears (with warranty that is offered by Sears).
Evdawg
979
i have 30 days to return it. If its not the problem then back to the store it goes. And dont anybody flame me for doing that, ive spent enough money at that store.
