- Apr 22, 2001
- 2,700
- 1
- 71
while moving my computer around in inadvertantly plugged my visioneer 4400 usb scanner power supply into my 3com 3c510 router and vice versa.  the scanner, which you'd think would be more fragile, is fine.  but i can't get the router to work now.  the green connection light comes on for the connection to the computer, but the steady blinking "system is okay" light is gone and i can't access the net.
i've tried letting it cool down, resetting it, the modem, tried using a serial cable to hyperterminal in (no response). anything else i can try, or should i just trash it?
