Im about to install a 1 gig Tbird with a Taisol 742 thermal pad. Mikewarrior2 or other techies help....please :)
Stylewar
554
I was made aware by another Anand user that it can be a bit tricky to install the heatsink properly to the CPU using the thermal pad. Perhaps some of you can give me any good advice you have so I can avoid frying my CPU. Thank you kindly in advance,
Joe
Modeps
17,254
44
Ive got the same setup... just follow the instructions on Taisol's website on how to put it on and you'll do fine... make sure you use a small screwdriver to get that clip on properly (like they say) piece of cake...
Heres the Link
